11-21-2023 08:50 PM
Hello,
I am trying to port my number to Public Mobile and unfortunately used the IMEI and got a text message saying it had trouble going through the process and someone will contact me.
I know this has occured to others and wondering whats the easiest way to resolve this and port the number?
Thanks.
11-21-2023 08:53 PM
@Notyourconcern wrote:Hello,
Carriers don't usually contact anyone when number porting number port encounters an issue. Please open a ticket using by asking for a customer support agent in the chatbot at:
If the chatbot shows and error message, please send a private message to CS_Agent:
11-21-2023 08:51 PM
@Notyourconcern using IMEI for porting info might not work all the time, best to provide them the account number of the old provider instead
There is a number to call to talk to live support and provide them the correct info again. They can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
