11-09-2016 06:35 PM - edited 01-04-2022 06:10 PM
I Ported my wind number to Public Mobile and just found out it had recently been rendered inactive. Now incoming calls receive a message that the number is not in service. I can make calls and use data, but no incoming calls. I received an error text message from Pm. What are my next steps? Can I revert to the number I was using before the port attempt, or can this port be processed?
11-11-2016 01:08 PM
Hey @Tcoop
Rest assured that Shazia will get to you shortly - wait times are longer than expected.
Mary
11-10-2016 03:33 PM
11-09-2016 06:39 PM - edited 11-09-2016 06:41 PM
You should private message a moderator, they will be able to help you.
How/when to send a private message?:
Please click on this tag -> @Shazia_K and on the right hand side if the page, press "send this user a private message". Hope that helps! Cheers! ![]()
