Port out
Abdullah909
I am attempting to port out. I responded yes to the text message but nothing has happened since yesterday. How long will it be?
@Abdullah909
After replying to the confirmation text then the calling and data should work in a few minutes but texting could take up to 2 hours for it to work.
If you are having issues then contact your new carrier to help you.
CSA_PM
Customer Support Agent
Hi there, to review your case, he have sent a private message, please review your community inbox to continue with the Public Mobile support team.
hairbag1
@Abdullah909
is your old sim still in the cellphone ? If so, remove it and install the new sim. See if that helps.
edit
