03-01-2024 12:02 PM
05-05-2024 01:19 PM
I have been trying for over a week to port my number to a different provider. No help, no response. Only poor service
03-01-2024 01:25 PM
You have to have public mobile service your main service and activated as you would need to receive the text message to confirm and that you get 90 minutes to confirm or it wont go through.
Once you do that part its smooth sailing. You may need to have a usa add on if your in the usa to receive this text.
03-01-2024 12:47 PM
Depends where are? Some have said they can receive texts in the US even without an add-on but other countries you will not receive any texts to authorize your port out.
03-01-2024 12:38 PM
Will this work even if I am out of country? I didn't think i could get PM sms messages if i was in another country?
03-01-2024 12:36 PM
Hi @Lens54
So basically, you need to go into your settings and pick the Public Mobile SIM card as a primary for now so you get the porting request from Public Mobile. Then once you get it you can take out the SIM card. OR if you have another phone or can borrow someone's spare phone for a few hours, then reach out to your other provider and request the porting request again. That will work.
03-01-2024 12:30 PM
I don't understand the currently have a second line on your account? This is impossible as each phone number is it's own account.
03-01-2024 12:17 PM
My account is still active (currently have a second line on my account). my sim card was deactivated when i received my new esim from new provider.
03-01-2024 12:10 PM
Hello @Lens54
1. Make sure your PM account is still active and your PM SIM card is still in your phone. If you didn't get the porting request on your PM SIM card/phone within the first 2 hours, it probably didn't go through. You need to reach out to the other provider to try again.
Porting requests to other service providers are done on their end.
03-01-2024 12:10 PM
Is your PM line active? It needs to be active to port out, and you should be sent a text from PM to authorise the port.
03-01-2024 12:05 PM
