02-20-2023 12:28 PM
I recently had number ported can call out but can’t receive a call text message works fine
02-20-2023 11:16 PM
When the incoming calls stop on the previous provider’s SIM card and/or landline/voip account, that is a good indication the port is complete.
If still issues, submit a ticket with Public Mobile representatives (CSA) for help; click this link for issues with transfer/porting of phone numbers over to Public Mobile.
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
02-20-2023 01:23 PM
How 'recent'? If you did reply "YES" to the port authorization request, authorizing your number to be ported here, then try :
02-20-2023 12:56 PM - edited 02-20-2023 12:57 PM
i guess you didn’t reply to the text confirming you are porting over to PM with the old SIM in the phone. There is a 90 minute window for you to reply or else porting will not be completed.
You will need to contact a CS_Agent to restart the porting process.
Meanwhile, your old SIM should still work.
02-20-2023 12:44 PM
It looks like porting is not completed or it failed.
Calling out is possible as you have been assigned temporary number.
Did you follow porting procedure to the letter?
02-20-2023 12:29 PM
A critical part to porting is to receive a text from your old provider and you have to reply YES within 90 mins. If you are not receiving calls and text on your PM sim card and can only make outgoing calls, then you might have missed the step and hence porting was not completed
There is a number to call to talk to live support, they can re-trigger the process for you. I will message the number to you via the Community inbox. Check the envelope icon on top right. Call them and get it fixed
