11-06-2022 06:47 PM
Received a voicemail earlier that there was an issue with my Port from Zoomer and was given a phone number to call back. I called and the rep was not able to find my number at all.
Service
11-07-2022 01:15 AM
Can you confirm whether or not you recieved a PAT (porting authorization text) from Zoomer?
Thanks.
11-06-2022 08:34 PM
I just ported out from Zoomer to public mobile today! They don’t send a text to confirm anymore. Also Pick cityfone as your carrier (because Zoomer isn’t an option) when prompted by public mobile as your porting your number.
11-06-2022 07:36 PM - edited 11-06-2022 07:37 PM
@GaryB58 ok, in this case, login to My Account. Go to Profile Page, then click Change phone number. Go to Transfer number tab and re-request porting.
Please enter your Zoomer account number instead of IMEI as the porting info
Once submitted, wait for textbfrom Zoomer (Zoomer sim in a phone) and reply YES within 90 mins
11-06-2022 07:25 PM
11-06-2022 06:55 PM - edited 11-06-2022 06:56 PM
@GaryB58 that's the number
call again, enter your number again after it says it cannot find it the first time, it will then connect you to live person
11-06-2022 06:55 PM
That is the correct number for the porting team, @GaryB58
Is your service with Zoomer still active? It needs to be to ensure a successful port.
11-06-2022 06:52 PM
18442327678
11-06-2022 06:51 PM
@GaryB58 what number is that? I am going to message you a number, porting team. if first time it does not recognize it, enter again and it will connect you to live support. Check your Community inbox
11-06-2022 06:50 PM
Contact a PM agent:
- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
- Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work.
During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
- Monday to Sunday: 6 AM to 10 PM EST
Keep an eye on the envelope icon in top right hand corner for a reply from the agent.
