07-18-2022 08:05 PM - last edited on 07-18-2022 11:38 PM by computergeek541
Hi,
How can I request for another port in. Tried calling Rogers and they said my number still active on their end and the port process must take place within 72 hours.
Thanks!
John
07-18-2022 11:15 PM
It sounds like you missed the most important step to complete the porting process…reply to the text confirming you are porting over to PM with the old SIM in your phone…there is a 90 minute window to reply…it sounds like you didn’t reply to the text.
You need to contact a CS_Agent to have the porting process restarted on this Community page.
07-18-2022 08:50 PM
Or @Jjdden342000 you can submit a ticket to Public Mobile representatives (CSA) directly using this link to request the transfer of your number over to Public Mobile.
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
07-18-2022 08:23 PM
@Jjdden342000 there is a number you can call to talk to live support and ask them to re-trigger the process/the text. I will message you the number. Check your Community inbox, envelope icon on top right.
07-18-2022 08:09 PM - edited 07-18-2022 08:19 PM
Did you leave the Rogers sim in to confirm the transfer? If you're inside of 90 minutes since trying then put the old sim in and reply.
Call this if you're over 90 minutes. And leave the old sim in.
Adding - slight re-arrangement
07-18-2022 08:07 PM
contact to support team by CS_Agent
