03-14-2023
11:00 AM
03-14-2023
03:03 PM
computergeek541
Tried using self help to manually port phone number but had trouble with previous provider account number.
03-14-2023 12:45 PM
Dial *#06# to get your IMEI of the phone to complete the porting of your old number but best to use your old account number from your old carrier.
03-14-2023 11:51 AM
@Kathy9 - where are you getting into trouble? Are you going through the SIM card activation process? Or, change number(Transfer/port) function in your My Account?
NOTE:
When the incoming calls stop on the previous provider’s SIM card and/or landline/voip account, that is a good indication the port is complete.
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
If still issues, submit a ticket with Public Mobile representatives (CSA) for help; click this link for issues with transfer/porting of phone numbers over to Public Mobile.
03-14-2023 11:13 AM - edited 03-14-2023 11:15 AM
Is the prior provider account still active? It needs to be to Port the number from there to here.
public mobile can pull a number from Telus or Koodo closed account, but it does require customer support agent assistance.
03-14-2023 11:05 AM
@Kathy9 you can try using IMEI but it could generate error. Best to use account number
But for account number, you have to call your previous provider and check with them instead, we cannot help here
Once you are ready, you can porting with activation together
Or if you are existing member, just login My Account , go to Profile page and chlick Change phone number, and request Transfer in there
