08-03-2017 02:40 PM - edited 01-05-2022 02:34 AM
Can anyone officially give the reason why we hear this message?
Thank you.
08-04-2017 08:10 PM
Yes, I understand this also. Your advice as I've also provided at the +1 to remove the problem, and deal with it when it actually doesn't connect/
08-04-2017 07:45 PM
@stonechucker yes, nowadays, PM doesn't have anything but province-wide calling. But they haven't updated their system to reflect that. So even though it's impossible to have a plan on PM where calling from Toronto to Ottawa is considered a long distance call, the system doesn't seem to know that and it's still playing the message for folks accordingly.
08-04-2017 07:28 PM
@WearySky, unless I'm mistaken, the minimum, usable voice package at Public Mobile, is unlimited province wide, which means no extra charge to a call. Whether it is local (ie landline years with 7 digit call), or long distance within the province is totally different things.
As I explained above in my post, you can have a local call in the province within the same area code, and outside the same area code (overlays like 519, 226, and there's a new one also). A local example is Brantford to Simcoe (both in Ontario), but a long distance example is Brantford to Cambridge (any of the three old towns of Galt, Preston, and Hespeler .... side note - come on telephone people, they merged in 1974 as Cambridge). Those are all within that area code grouping.
And this is also a problem, for those living in Provincial border areas. The big one I keep referencing, Ottawa to Hull / Gatineau area, two provinces, one local calling area, and Public Mobile DOES NOT recognize local calling areas in the plan selections - a huge error in my opinion.
@WearySky wrote:If you didn't have an unlimited provincial calling plan, the call you're making would be considered a long distance call. That's all that it's telling you, really.
08-04-2017 05:26 PM
08-04-2017 11:49 AM
I hear ya OP - it's a total PITA, but it is what it is.
08-03-2017 04:38 PM
I actually updated all my contacts to have a +1 in front of them, years ago, when I first got a Canada-wide calling plan with Rogers specifically so I'd avoid getting that message (I feel like they fixed their network so that people with Canada-wide or province-wide calling don't get those messages anymore though). Thanks to cloud-based contact storage, I've never had to update them again 🙂
08-03-2017 04:37 PM
Maybe it's the way Public Mobile provisions their calling plan. I had issues early on with so called long distance and toll free calls, but the problem seemed to resolve itself. I have too many contacts in my address book and I am not about to edit them manually and add a 1 in front of every number.
08-03-2017 04:13 PM
@Michael77, what I do so I don't get those messages is any number I store I put a 1 in front of the area code. No more messages, and the call wouldn't go through if it was long distance and you don't have the long distance addon
08-03-2017 04:06 PM
Ignore all messages unless the call does not connect. It's one of Public Mobile's idiosyncracies.
08-03-2017 03:58 PM
08-03-2017 02:48 PM
I will try to explain this again.
If you're dialing a number in the same province, and the same area code, it can still be a "long distance" call.
If you're dialinig a local call (land-line terminology), in the same or different area code, it's not a long distance call.
If you're calling a number in the same province and a different area code, it could be either a long distance call (ie Kitchener to Toronto), or a local call (Kitchener to Waterloo).
This stems from change from 7 digit dialing, to 10 digit dialing years ago, possibly before your time making phone calls... it did happen about 20 years ago.
A local call can be completed, with only 10 digits, if it's in either the same, or different area code. But if it's not a "local" call, the warning message is designed for all users who may or may not have long distance packages.
If you're on a plan with long distance, you don't have to worry. If you know it's a local call, call +1 then the number, or just let it dial.
This is not an offical statement, it's just my extensive experience calling from 7 digit to 10 digit requirements previously.
