6 hours ago - last edited 6 hours ago
6 hours ago
6 hours ago
Check the outage map:
https://istheservicedowncanada.com/status/telus/map
Depending on the damage to the infrastructure. It may take sometime.
6 hours ago
@JenXie are you talking about your home internet or Public Mobile service? If you are having issues with your cell phone check to see if there is in outage in your area:
" @JenXie wrote: No internet service at home on 2024-08-19. Wondering what is the cause and when it will be restored. Thanks."
i checked this for Telus outage: TELUS Service Status
it only has a rainwall warning for Ontario , but it says no impact to Telus services
did you check if you used up your data ? and try reboot the phone and try Reset All networks
if you still experience no data problem, ask PM directly. Just open ticket with PM using the Orange Chatbot icon on the lower right. Type the question Submit ticket and select Contact Us to get to ticket open screen
or message them using this link:
