06-13-2024 02:25 AM
I've tried every solution I can find. If I press 1 I can access my voicemail no problem but the issue is my voicemail never picks up, Will ring forever and if I ignore call it just goes to busy signal. Google Pixel 7. This is quite vexing.
06-13-2024 04:30 PM
Thanks for the reply, The number in my VM is not in my area code. I created a ticket yesterday so hopefully they get back to me. Thanks
06-13-2024 04:28 PM
Hello, when I do that I get "Call forwarding
MODEM_ERR"
06-13-2024 07:05 AM
please dial ##004# to reset all conditional forwarding and it will set it back to voicemail
06-13-2024 05:46 AM
Does calling voicemail result in a number that goes to your (area code) + 580-4001?
Check your voicemail calling number on your individual device. If you need assistance, contact customer support as below:
