06-21-2022 02:38 PM
I cannot remember the answer to the secret question
Please help to unlock my account
06-21-2022 02:43 PM
Hi you need a cs agent Click here or if you are having issues with Simon you can send private message to a CS Agent here: https://bit.ly/2GGCJzH
06-21-2022 02:42 PM
HI @kimadaeyeon6439 since you tried Forgot password and unable to get pass the secret question, please open a ticket with PM CS agent and they will reset it for you
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
06-21-2022 02:40 PM
@kimadaeyeon6439 You'll need to submit a ticket to customer support via chatbot here: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
If unable to submit a ticket send a private message to CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
