07-15-2019 08:58 PM - edited 01-05-2022 05:54 AM
Looking for a cheap first phone for my daughter, and I'm wanting to confirm that this phone will be compatable with Public.
I'm thinking it is based on the info given, but I'm pretty noob when it comes to cell phones.
07-23-2019 08:48 PM
@Mothman hi all should be good don't try to fix it if it works!! ![]()
07-23-2019 08:44 PM
Follow up to this thread.
I received the phone, and set up a new sim.
I didn't change the APN at all, just left it as is (and I notice I don't have the option to add a new APN if I wanted to, which I understand is the issue that was being mentioned).
However, I have data... I tested by turning off wifi, and it works fine.
The APN fields that defaulted contain all of the same info as shown for my phone here: https://apn-canada.gishan.net/en/apn/public-mobile, other than the name of the connection is not "Public Mobile 2" . All other fields are already pre-filled as required.
I'm assuming that this is totally cool, and that the setup managed to auto-complete all of this for me... but just wanting confirmation... I don't have to actually add an APN is the one it defaulted to is already working, correct?
07-16-2019 12:32 PM
Thanks all. Great community here. 😃
07-16-2019 12:29 PM
Android 8.0 and 8.1 have been difficult, but not impossible to update. You'll get through it, and we're here to help.
07-16-2019 12:26 PM
Sorry I should have been more specific.
I understand the need to set APN settings... Just worried now about the comment that the OS on this phone may make that problematic.
I've searched the forums and see lots of discussions on it... Crossing fingers I'll be able to get this phone to work
07-16-2019 12:23 PM
@Mothman wrote:What does that mean? The APN comment?
I've.ordered the phone so I hope there is a way to make it work.
APN refers device settings that need to be set correctly to use mobile data.
07-16-2019 12:17 PM
07-16-2019 10:52 AM
@Mothman wrote:Looking for a cheap first phone for my daughter, and I'm wanting to confirm that this phone will be compatable with Public.
It should work but it looks like it comes with Android 8.1 which means it may be a little difficult to set up your APN.
07-15-2019 09:02 PM - edited 07-15-2019 09:03 PM
07-15-2019 09:01 PM
Thank you. 🙂
07-15-2019 09:00 PM
Based on the Link Provided it will most definitely work
