02-20-2024
08:16 PM
02-20-2024
09:18 PM
computergeek541
Trying to use my mobile hotspot to play my PlayStation Portal. I have a 5G plan and iPhone 12.
when testing it will try to connect to my PS5 and it will turn it on but will not give me access.
I tried changing the APN and didn’t work. However on my old phone I did eventually get it to connect once and play. iPhone 11. I changed the APN and then changed it back and it eventually worked once. So I assumed getting an IPhone 12 with 5G would be better.
has anyone been able to get this to work?
an issue apparently might be the NAT 3 that is provided from the hotspot. Possibly a NAT 2 would work.
Frustrating as apparently Sony said Roger’s and bell work for the portal.
02-20-2024 09:50 PM
02-20-2024 09:47 PM
No I see that. The hotspot works and it turns on the PS5 but for some reason it won’t “connect” enough to give me access and play. Thinking maybe it is a PlayStation problem. But just a bit mind boggling that I got it to work once from my IPhone 11.
I tried my wives iPhone with my sim. And also tried using her hotspot from her sim with the same plan.
02-20-2024 09:33 PM
Rebooting both iPhone and PS portal after every step.
02-20-2024 09:26 PM
PM does not block hotspot, so, it is a matter of the settings on your phone
Test your sim in another phone if possible. And, I hope you tried a device reboot already
02-20-2024 09:25 PM
Unfortunately these steps did not resolve the issue.
02-20-2024 08:19 PM
try this
1. Try to reset the network settings
2. To to reseat the sim card. Turn off the phone, remove the sim for a minute before you put it back in and setup Hotspot again
3. Check APN, go Settings -> Cellular -> Cellular Data Network -> PERSONAL HOTSPOT / APN -> sp.mb.com , and Leave Username and Password blank.
