12-27-2022 06:29 PM
12-27-2022 08:50 PM
12-27-2022 08:49 PM
@Richard19 @Happy to hear it all worked out for ya , yay !!
12-27-2022 08:36 PM
Will buddy it worked and thank you and happy new year 👍🍺
12-27-2022 07:44 PM - edited 12-27-2022 07:46 PM
It's definitely accessible, @Richard19
I just tried in both mobile and desktop.
Maybe try reducing your screen size, perhaps the arrows to toggle plans is out of the screen view.
To view the list, tap change plan ...
12-27-2022 07:43 PM
@Richard19 usually they will reply within 2 or 3 hours, but could be longer
check your Community inbox often. And if no reply by tomorrow, message them again for update
12-27-2022 07:42 PM
thanks sent a message how long before they reply
12-27-2022 07:36 PM
@Richard19 don't give up, you are trying to schedule a plan change on next renewal anyway?
Open ticket with PM support via Chatbot and ask them to help schedule the change since you cannot find the plan yourself:
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
12-27-2022 07:34 PM
Anyway tried everything you guys said still no good when I go to switch plan on 4 gig I only have 1 choice and it’s not the plan I want so thanks think I will switch companies this is bull **bleep** thanks again
12-27-2022 06:49 PM
@Richard19 Incognito is a private browser
12-27-2022 06:49 PM
@Richard19 wrote:What is incognito mode
@Richard19 which browser you are using?
Generally click the 3 dots on the top right, select New Incognito Mode or some browser call it Private mode or InPrivate mode
click that and a new window or tab will open, then use that window to login My Account
12-27-2022 06:47 PM
@Richard19 the $45 - 20GB plan is there
make sure you are on the 4G speed tab and use the Yellow arrow on the far right (or bottom if you are using mobile ) to scroll down
12-27-2022 06:47 PM
@Richard19 It’s definitely there as option so if your not seeing follow my link and let us know how you make out .
12-27-2022 06:47 PM
@Richard19...it's there. Just select 4G / then use the down arrow to get to your new plan. Refer to the screen shot, above.
12-27-2022 06:47 PM - edited 12-27-2022 06:48 PM
When you're on the plan change page, you'll see small arrows to the right.
Tap on this to see more plan options.
And always remember to switch on NEXT renewal to avoid losing what's left in current cycle.
12-27-2022 06:46 PM
12-27-2022 06:44 PM - edited 12-27-2022 06:45 PM
@Richard19 @What plan you looking for? if it’s not there but you can see it on the website you can try and talk to agent here in the community about it
Getting help from agent , through automation
- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
Or get direct help from a agent right here in the community ( my preferred choice )
- Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to wjork.
12-27-2022 06:44 PM
45 dollars 20 gigs
12-27-2022 06:42 PM
Which plan are you considering a change to ?
12-27-2022 06:40 PM
I know but when I say change plans it only shows me 1 plan and it’s not the one I want
12-27-2022 06:33 PM
@Richard19 @I would change for next renewal so you don’t lose any service
12-27-2022 06:33 PM
@Richard19 what error you got?
Try again using Incognito mode
Also, make sure you understand the difference between 'Change plan now' and "Change on renewal date" and pick the correct one Usually people choose "Change on renewal date" to avoid lossing money, unless you need the new data, minute urgently
12-27-2022 06:32 PM
@Richard19 @You need to sign I to your pm account and go to plan / add on n change plan
12-27-2022 06:31 PM
Log in to your account using incognito mode. Then make your selection. Decide now if Change at Next Renewal OR Change right away.
