06-27-2023 12:25 PM
If you change plans from a $15 plan month too a $39 plan a month can you go back to the 15$ plan again if you want too?
Plans
06-27-2023 01:26 PM
HI @Snuggle-bug no rule to stop you from change plan here.
Make sure you use Change on Renewal.
06-27-2023 12:29 PM
Yes no problem to change plans
06-27-2023 12:28 PM
@Snuggle-bug yup, Good thing for PM is no contract no commitment. You can always change to new plan whenever you want, as long as the plan still available. $15 is not going anywhere, it is there to fulfill CRTC requirement
