07-31-2022 06:54 PM
07-31-2022 07:38 PM
@SAlexander the good thing for PM is that you can change plan whenever you want , no commitment, There is no problem whenever one month or more .
But one thing, if you have the activation bonus, one of those 2GB Bonus for # months , then thay will be gone with a plan change. But of you don't have one, no worry then
07-31-2022 07:10 PM
The good news is you cna jump back and forth even month to month on the plans you want. You just have to be mindful of any bonuses you may have tied to your current plan, for example a 2GB bonus could be effected if you are either going down below the $$$ threshold of the conditions or even if you upgrade but are going from 3G to 4G they said they would pull your bonus as well
07-31-2022 06:56 PM - edited 07-31-2022 06:58 PM
Very easy to do @SAlexander 🙂
Read this over on how to change your plan:
https://www.publicmobile.ca/en/on/get-help/articles/change-your-plan
Recommended to change on new next renewal, so you do not lose out on any $s in this current cycle as dollars are not prorated if you choose to change your plan now.
edit, word correction
07-31-2022 06:56 PM - edited 07-31-2022 06:57 PM
use browser from computer, clear cache and cookies and use one page inPrivate mode,
