04-03-2022
04:30 PM
04-03-2022
05:10 PM
computergeek541
My Plan
This plan includes: -
- 10.5GB at 3G Speed
- Unlimited International Text
- Unlimited Talk to Canada and the US
$50/month.
I took a vacation in the states and I just tried texting back home and I got a text saying "Sorry, your plan does not include sending texts while in the US. Incoming texts are included. To add a US Roaming Add-On, visit selfserve.publicmobile.ca"
Service
04-04-2022 06:15 AM
@hiLeah wrote:Should've read the fine print.
But I also did get the add on for 10 days.
On my previous plan but it didn't work hence why I got the more expensive plan since it included the US talk and text.
@hiLeah - how long ago did you get the Roaming US talk and text add?
If it was with 10 days, and if you added it successfully, it should be listed under your Plan Details section in your self serve account.
Check your transaction history to see if you added it correctly: https://selfserve.publicmobile.ca/Overview/payment/Payment-History/
If you don't see it, then you likely missed step #2 in the purchasing an addon process.
1. Add funds to your account, if you don`t have sufficient funds
2. Go back to the Add-Ons page and select your Add-On.
For roaming:
- Make sure data roaming is enabled in your phone settings.
- Restarting your phone should help you connect to the correct network.
- Go to the cellular or network settings in your phone, and check your APN configuration. If possible, manually search and select T-Mobile's network.
04-03-2022
07:32 PM
04-04-2022
12:01 AM
computergeek541
04-03-2022 04:53 PM
@hiLeah - did you recently get this plan in order to travel to the USA?
If so, that is unfortunate.
See the details of the plan at the bottom underlined in red.
In order to have other Public Mobile...other than incoming texts, you will need to purchase ROAMING Add-ons, found here in your self serve: https://selfserve.publicmobile.ca/Overview/plan-and-Add-ons/ChangePlanLandingPage/?PageRedirect=Redi...
You can also call 611 or # 1-855-478-2542 from another device (needing your 4-digit account PIN for this process) to purchase 10 DAY only ROAMING addons.
Safe travels.
04-03-2022 04:53 PM
@hiLeah wrote:That's abit stupid considering its already added to the plan though. I'm literally paying extra..
Talk, text and data services refer to services offered while connected to the Telus/Public Mobile network. For service when not connected to the Telus/Public Mobile network, a roaming package must be purchased. Calls must originate from Canada to the US.
04-03-2022 04:40 PM
You're not the first to ask about the term "international text". Services only work while in Canada or with add-ons in the states. The next line says "to Canada and the US". Also not the first to ask. Again, only while in Canada.
To call in and out and to text out and data you need the US roaming add-ons while in the US and wishing to use the Public service.
04-03-2022 04:36 PM
It's a 2 step process to activate the add on. First add the funds and then choose the add on
04-03-2022 04:33 PM - edited 04-03-2022 04:37 PM
You purchased and applied a US roaming add on?
Again, the $50 & up plans only include u.s. calling and texting both ways while you are physically in Canada.
04-03-2022 04:33 PM
04-03-2022 04:32 PM
I did that and it still doesn't work.
04-03-2022 04:32 PM - edited 04-03-2022 04:32 PM
Your plan works ..while calls or texts originate in Canada. You'll need an add-on for use while in USA.
04-03-2022 04:31 PM - edited 04-03-2022 04:32 PM
It's likely your phone automatically connected to a US Network.
The $50 and up plans includes us long distance while you are in Canada. In order to use service while in the US you will need a US roaming add-on
