Autopay
04-04-2022
12:07 AM
04-04-2022
12:12 AM
computergeek541
04-04-2022 06:32 AM
@nusratzahan wrote:Why isn't my autopay being applied? I registered on 4th September.
@nusratzahan - you have never received the Autopay reward since September?
First, confirm you have a card registered on your account, and see if at the bottom of your overview tab it says you are "registered for dynamic Autopay":
If so, then check your transactions history, found here: https://selfserve.publicmobile.ca/Overview/payment/Payment-History/
You can go back up to 6 Months, or 1 year by selecting the calendar selector dates.
If you do not see any "Autopay reward" for $2 listed then contact Customer Support Agents (CSA) to inquire about this.
To contact Public Mobile Representatives (CSA), by either two methods, found here:
04-04-2022 01:24 AM
Oh I see. You were asking about the reward, not that the autopay worked. So is everything currently working?
Can you look in payment history for the credit of the autopay $2? You might be thinking of taxes being charged on your credit card. Or give an image of your payment history.
04-04-2022 12:48 AM
April 1st debacle that happened. There was a system malfunction.
04-04-2022 12:41 AM - edited 04-04-2022 12:42 AM
If you registered after January 25/22, you are registered in the Points system not the old Rewards system and there are no points for using AutoPay.
But you will get $10 credit if you used a friend or family referral code.
There was a bug on April 1 and a days or two afterwards.
Best that you contact a CS_Agent to straighten the AutoPay problem out.
04-04-2022 12:33 AM
It is most likely related to the payment outage on April 1st, some are still dealing with it. You will find many threads on this and if those steps don't work open up a ticket with a CSA
04-04-2022 12:18 AM
No I applied for autopay immediately after registering.
04-04-2022 12:18 AM
It doesn't make sense why I NEVER got the rewards applied 😞
04-04-2022 12:12 AM
Are you in the middle of renewal? Autoapy and plan renewals do not happen immediately at midnight. The exact timing varies (sometimes) greatly from renewal to renewal.
04-04-2022 12:11 AM
By my rough estimation that puts you in the April 1st debacle that happened. There was a system malfunction. Many people have been fixed. Some still not. Contact the support people to register your problem and they should fix up your account.
