Plan
martinab
Need help switching plan to the 15$ starting next monthly cycle. "Agent"
pkaraa
You wont need an agent for his request. Follow the process shown above and you should be able to choose from change plan right now or at next renewal. That is all you need.
Spudster
Like this @martinab
Here’s the process for changing plans, first login to Self Serve to this screen:
Then, click Change Plan:
Then select desired Plan:
Then choose Change on Next Renewal Date:
HI @martinab   You can just login to My Account, click on the Button Change Plan.
Then select the plan you want to change to and remember to click "Change on the next renewal date"
Meow
Very simple.
Click on Change plan, pick $15 on next page and click on 'Change on next renewal date'
@martinab
Just login to Self Serve account and click on My Plan>Change Plan but do it the day before your renewal date so you don’t waste the existing plan and paying for the new one.
ShawnC13
@martinab, go into your self-serve and go to change plans and you can schedule it to do that on your next renewal.
* I am happy to help, but I am not a Customer Support Agent please do not include any personal info in a message to me. Click HERE to create a trouble ticket through SIMon the Chatbot *
