01-09-2020 05:30 AM - edited 01-05-2022 10:16 AM
01-09-2020 12:35 PM
You can keep the old plan as long as you want, but you can't undo a plan that is no longer available. Before making any changes, please check your current plan to see if it is worth keeping because some of the current plans may offer better value.
01-09-2020 12:21 PM
@gordone27 of course you can, but if you decide to change, you will not be able to switch it back. So, think wisely before actually changing current plan.
01-09-2020 09:44 AM
@gordone27 wrote:Are you able to keep a grand father plan
Yes, but you check it against the current plans to see if it is worth keeping.
01-09-2020 06:52 AM
Yes if you have a grandfathered plan, you can keep it even if the plan is no longer available to new customers. As pointed out, if you change plans, you cannot get it back.
Some plans that are worth keeping and not offered currently:
- $10 plan (minimal use plan including 50 texts and 50 minutes)
- $60 plan (includes Canada and USA coverage)
- any customized plan
In some other cases, it may not be worth keeping the older plan because the current plans offer better value for your dollar. You can take a look at what plans are offered currently to compare.
01-09-2020 05:58 AM
They could chnage your plan but they usually don't. Some prices have been raised before.
01-09-2020 05:54 AM
@gordone27 As long as you dont change it. Yes.
