08-20-2026 01:11 PM
08-20-2026 02:07 PM
Nope. My plan stayed the same since last price raise a year or two ago.
If you see $5 increase it is due to your phone NOT compatible with PM network and you would need new phone
08-20-2026 01:35 PM
If you meant plan price. NO, they rarely increase the price. We only see it 3 or 4 times in the past 10 years, affecting 4 or 5 plans on the lowest tier. That is like at most 5% of the plans ever see a price increase
08-20-2026 01:25 PM
@Angel1959 you plan typically will stay the same price unless you change plans yourself , I’ve only ever seen public mobile increase couple low cost plans over the years so it’s certainly rare for one’s plan to increase outta thin air . Hope this helps
