Coverage
Jgolfer
I have 5g but when away from wifi I only have lte coverage. Why?
1 REPLY 1
umnikke8
You have a device that supports 5G and something more common that supports the proper frequency bands used in Canada? Are you in a 5G coverage area? Check the coverage map. Even with a compatible device and in a coverage area, there are times you still may use LTE instead. It's not really a big deal, the LTE connection is often faster today and uses less power. As time progresses the 5G network will take over more and more.
