12-16-2022 08:02 PM
I recently upgraded to the 15 GB of 4g for 40$ and it was charged on my November bill. I just logged in to check my account and it says my an is the 1g of 3g for 25$ I did not do that so what happend? How do I go back to my 15gb for 40$ plan?
12-17-2022 09:11 AM
@Jesse4 wrote:Yes it is my old plan, what confuses me is that in November it said my plan was the 40$ plan so why did it change?
@Jesse4 no worry , you likely still on the $40 15GB plan. You could be just reading old cached page, a browser issue
Please use incognito mode to login to My Account and you should see the correct plan again. I would also use Incognito mode for accessing My Account to avoid confusion
12-17-2022 07:39 AM - edited 12-17-2022 07:41 AM
So it seems you got your answer, @Jesse4 .
It didn't "change" - you are very likely viewing a 'cached' version of the self-serve page.
You confirmed that the amount you were charged (from your credit card) was the new plan amount.
You were provided with the means to ensure you're seeing a non-cached (outdated) image on self-serve site.
When logged onto the site, this is the little spinner icons to tap to get a refreshed version of the page:
12-17-2022 03:07 AM
12-17-2022 03:06 AM
My last bill was 40$ and last month the plan it stated I had was the 40$ 4g plan as well.
12-16-2022 08:09 PM
What does your payment card (or credit card) display for a transaction amount?
The old plan, or the new plan value?
12-16-2022 08:09 PM
Click on all the little spinner refresh icons you see lower down or use private mode. You might also try another browser or even device.
12-16-2022 08:08 PM
@Jesse4 wrote:I recently upgraded to the 15 GB of 4g for 40$ and it was charged on my November bill. I just logged in to check my account and it says my an is the 1g of 3g for 25$ I did not do that so what happend? How do I go back to my 15gb for 40$ plan?
Is the $25 plan your old plan? It's possible that the Self Serve website is showing out-of-date plan details. Please log out, clear your cache, clear your cookies, and close your browser. Log back in (inccognito mode wouldn't be a bad idea) and check the details again.
