04-08-2020 09:59 AM - edited 01-05-2022 10:17 AM
Hi folks
How do I check number of minutes left in my plan? I dont want to count the number of minutes in usage history. I hope it's available somewhere in my account but not able to find it. Help me in your spare time.
Thanks in advance
Jeet
06-20-2020 05:27 PM
Just checked. I'm on the same plan and can see both my minutes and data. Is it possible that you are out of both of them? Did you have any minutes and data add ons @JordanB ? Thanks
06-20-2020 05:15 PM
Is this feature broken for anyone else? I can't see plan data or minutes left anywhere.
I have tried Chrome and IE, and the garbled text under My Data & Addons appears in both browsers. However it doesn't appear to be hiding my usage there either.
04-08-2020 04:28 PM
what i do is login to public mobile self service portal from time to time to check the minutes left in my account. im using the 15$ plan with 100mins. i also bought the 5$ addon which includes 500mins so that i have peace of mind. the good thing about that add-on is that it never expires!
04-08-2020 10:56 AM
Thanks @gblackma . So plan data. Maybe someone could check on a higher plan for their plan data.
04-08-2020 10:50 AM
I'm on the $15plan. @Anonymous 611 gives me the remaining minutes on the free 400 international minute add on and the free 1 gig add on combined with my plan data. It doesn't tell me how many minutes are remaining on my plan, or about the Canda wide 500 minute addon.
04-08-2020 10:22 AM - edited 04-08-2020 10:40 AM
The 611 service gives me minutes left of the 200 minutes, minutes left of the gift 400 minutes and total add-on data remaining. Interestingly not the 500 minutes which I guess makes sense since it's not available to purchase in 611.
It does not give me minutes and texts remaining of the $10 plan components.
I would then imagine that the $15 plan would be the same. Maybe someone with that plan would be interested in testing that.
04-08-2020 10:14 AM
@Jeet If you find that you are out of nearly out of minutes, add the 500 minute, $5 Canada wide addon. Heres an article on buying add ons https://www.publicmobile.ca/en/on/get-help/articles/purchase-add-ons-through-self-serve
Also To save more, add the TextNow voip app and use it via Wifi to make / receive / send calls and texts in Canada and to the United States for free. You can also use it as I do to check my voicemail from my own phone without using the minutes from the PM plan. Simply dial your PM phone number - reject the call when it rings (this sends the call to voicemail) - press the * key to allow you to enter your password. - enter - and you are in your voicemail account - Hang up when you are finished. No minutes used.
04-08-2020 10:11 AM
@Jeet wrote:Hi folks
Thanks in advance
Jeet
Once you log into My self serve account. Right under "My Data & Add-Ons" You will see how many mins you have used out of 100 MINS as showing on picture Below.
If you have the 25$ or Up plan, you have unlimited mins.
Cheers!
04-08-2020 10:05 AM - edited 04-08-2020 10:08 AM
@Jeet It should show it when you login to your account endless your on a unlimited canada wide calling Plan. Then that is pretty much useless You could also dial *611 and it should say your minutes usage there.
04-08-2020 10:03 AM
I believe the usage history only tracks minutes used and the account page does not show remaining minutes.
04-08-2020 10:01 AM
A couple of options:
1. Overview page will show your talk minutes counter in the Add on section
2. In the plans and add on tab, then choose usage tab for more detailed usage history
