Plan problems
JTGAz
I got notified of a plan to pay $40 for 15 gb of data. Then I said yes. When it was time to renew my plan I went to pay and it only charged me $5 and even after I paid I didn't get service. Then I switched to a 3 gb plan and paid it. It says my plan is active on my account but when I try to make phone calls half of the time it goes through and half of the time it says I am out of minutes. Submit ticket.
11 REPLIES 11
@JTGAz
You may be receiving $5 per cycle in Loyalty Rewards if you have been here this long, presuming you have not switched to the public points program.
If you also have Auto pay, you're receiving another $2 per cycle.
That's a pretty sweet reason for staying if you can get the calling issues sorted out.
Try your SIM in another device for a while, if available, to see if the problem resurfaces.
@JTGAz   every carrier will have hiccup once in awhile. Remember Rogers brought down the whole country for a day earlier this year?   With porting easily done, people come and go.  You might be able to bring back friends now with those good 4G speed plan
For your issue, wait for PM's reply.  If no reply after another 2 hours, message them again and push for an update
JTGAz
Yeah I've already opened a ticket. I already lost my refer a friend bonus because everybody I referred went somewhere else after pm service went to the pots in Toronto two years ago.
@JTGAz   Give PM one more chance.  I think it still something fixable
Have you open ticket with PM support yet?  If not , open one and they probably can fix it quickly
Please open ticket using Chatbot (Method 1) , or if it is too confussing , then just open by direct messsage (method 2)
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
JTGAz
So I logged in on incognito and refreshed. It is still showing an active plan with unlimited talk and text but when I try to call it says I have no minutes and I can't receive texts and outgoing texts don't reach their destination. Honestly this might be the last straw. I have been a pm customer for over 12 years and over the last 2 years I haven't received half of my calls and I've had to jockey for position just to make outgoing calls.
I was thinking the same thing, @Quigley
Quigley
You must have been sleeping at the wheel @HALIMACS 🤣
I should have thought of that, @Quigley
Quigley
@JTGAz
To see the latest information in your account, you should login to your account using a browser in incognito or private mode instead.
Then refresh your overview page using the little circular refresh wheel.
HALIMACS
If you wish to submit a ticket, @JTGAz , here's how:
  1. Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select Contact Us, then select Other (or the topic that more closely matches your request).  Click the result which states Click here to submit a ticket and follow the prompts,  or,
  2. Send a private message to the Customer Support Agent by clicking here  You’ll need to be logged into your Community account for the link to work.
HALIMACS
@JTGAz
What you're describing could be login issues related to PM's self-serve site caching issues:
  • Try clearing cache and cookies and opening an incognito tab
  • Try using a completely different browser from a completely different device which does not have stored/remembered credentials
  • If using a device with stored/remembered credentials, sometimes when these autofill, the device also attempts to automatically log you in.  If a device does this, do not tap the sign in button while it is trying to log you in as it will deliver an error message
Another option when logged in is to tap the yellow area below:
