12-25-2022 01:20 PM
If I make changes to my current plan will I loose my monthly rewards?
12-25-2022 01:40 PM
Only a couple of things would cause you to lose your monthly rewards, @Mikio
12-25-2022 01:32 PM
Simple answer is - NO. Your rewards are tied up with Account, not plan.
12-25-2022 01:22 PM
You will not lose the reward system you are currently on by changing plans. Rewards are independent of plans.
12-25-2022 01:22 PM
No you won't lose any of your current rewards, because they are attached to your account and not the plan you have.
12-25-2022 01:21 PM
@Mikio No you will not , you get to keep your loyalty rewards
