02-28-2026 10:08 AM
02-28-2026 10:38 AM
HI @Macuser007
did you use Change Now option?
did it give you an error about payment?
or did you use Change on Renewal and today is the renewal day and you don't see the new plan? if it is the case, it could be just a browser cache problem. Please try again using Incognito/private/secret mode on your browser to login My Account, or try using the PM app (logoff the app first and log back in)
02-28-2026 10:34 AM
@Macuser007 Might just be cache issue if you log into the public mobile app and swipe down from top of the screen it should refresh and show the proper plan , if not then get support to investigate
you can use the orange chat bubble bottom right of screen or send a private message To CS_Agent
