Plan change
Publiccell
I would like to change my plan to include US access
JL9
Unfortunately no option for a plan that would cover this, PM used to have a CAN/US option but it is a grandfathered plan, some customers come on here and still talk about it, would be nice if you are doing a lot of travelling but no dice if you are looking for that type of plan now
@Publiccell
Plans on PM can only be made with calls from Canada and doesn’t have plans including US Roaming.
You need to make a separate US Roaming Add-ons on a 10 day durations.
MrSpock
@Publiccell Hi do you mean while in the states? If so there are only 10 day roaming add ons
@Publiccell   if you meant roaming in US, there is no plan include that at the moment.
You will have to go with buying Roaming Add-ons, but they all come in 10 days period,
