Plan add ons
papasmurf
Which add on should I add so I can make calls and text's from Hawaii to Canada
Bj2001
Don't count on the USA Addon with calls and texts to work - every second one I put on my phone doesn't work and it takes days for PM to even deal with it or fix it - I hope you don't have the same frustration we have with this crappy service.
hairbag1
Your 10 days start as soon as you buy it...if you buy at 10pm...that's day 1....then day 2 starts at midnight. Plan your purchase wisely.
You'll need a U.S. roaming call add-on. There is a $15 add-on that includes that and it lasts for 10 days.  Make sure that you don't take a long distance add-on by mistake.
