07-30-2026 03:01 PM
I have an account / plan for my son to use for emergencies. I believe it needs its payment details updated.
I don't recall the email address to access it. I know only the mobile phone number.
How may I get access to the account or is it dead now and I need to sign up a new account with another provider?
07-30-2026 03:08 PM - edited 07-30-2026 04:00 PM
if you need to pay urgently to resume service, consider paying by voucher first. Buy a voucher from Shoppers drug mart or Loblaws or No Frills and then load the voucher using *611 or My Account
This is the full list of retails that you can buy vouchers. Vouchers in some stores need to wait 24 hours, but vouchers from Shoppers and Loblaws can be redeemed immediately:
https://www.publicmobile.ca/en/payment-voucher
On top of physical stores, you can also buy online with extra service fess: buy from muskbird.com , ding.com , recharge.com
With the login, PM support agent can help. You can submit ticket by direct message:
07-30-2026 03:06 PM
use the Forgot email on the login page and it will send you an email, then check all the possible email addresses.
but if you still cannot find the email you used, ask PM and they will help
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
