Pin wont work
connielangille4
My pin wont work for my account or my service for changing option or add ons
@Luddite thank you. edit done
@RosieR FYI: PIN needed to make purchases after dialing 611.
RosieR
Hi @connielangille4 Welcome to Public Mobile!
What do you need your PIN# for?  What options do you need changing?  If you want to purchase add-ons on self serve, you don't need a pin# to do that.  Apparently if you try to purchase add-ons on 611, you need your pin#.
Please give us more information so we can help you better.
RosieR
HALIMACS
@connielangille4
I can't be certain, however I believe your PIN is sent to you via text when you first activated and selected one.
Perhaps check back in texts from Public Mobile around account activation.
To change or reset your account PIN, you'll need to ask a moderator.  Please open a ticket at:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html
