03-16-2020 06:26 PM - edited 01-05-2022 11:09 AM
03-16-2020 06:30 PM
PIN is used for various identification purposes. Write it down and save it !!
03-16-2020 06:29 PM
You need the pin to verify to the mods you own the account. It helps knowing it if you ever port out too.
03-16-2020 06:29 PM
@Caitlyn1 You use your pin to apply payment and purchase add ons through 611 from your phone. See link on how to use it https://productioncommunity.publicmobile.ca/t5/Self-Serve/611-IVR-Menu-System/m-p/289352#M20315
03-16-2020 06:28 PM
@Caitlyn1 When dialing 611 you will need your PIN to purchase add-ons. Also you might need when communicating with PM Moderators and also porting your number out. So keep it in a safe place.
