04-09-2018 01:43 AM - edited 01-04-2022 04:03 PM
When I try to send a picture text is says waiting for service but I have 3 bars. I can send/receive normal texts, make/receive calls, and use data with less signal?
Joining Public
04-09-2018 07:54 PM
Awesome, glad you got it working .
GC
04-09-2018 07:49 PM
I had a capital in the MMSC by accident.
Thanks
04-09-2018 01:41 PM
may need a factory reset. a lot of the LG's needed to do a reset to work properly.
04-09-2018 11:03 AM
@jp2 For more detailed help tell us the make/model of your phone.
04-09-2018 10:40 AM
Check the MMSC APN setting again to be sure. Check closely for spelling:
http://aliasredirect.net/proxy/mb/mmsc
GC
04-09-2018 09:38 AM
Yes APN is correct, data works fine, and i can receive picture texts
04-09-2018 08:23 AM
To be clear, data needs to be enabled and APN settings have to be entered properly. But sending pictures via SMS does not use any data and you do not require a data plan or data add-on.
04-09-2018 06:02 AM
Have you setup your apn on public mobile network properly?
Does your data work on public mobile network?
Does incoming picture message work?
Picture message relies on data.
