11-01-2016 09:43 AM - edited 01-04-2022 04:03 PM
Hi All
i acctivated my New sim 2 days ago and ported my number while i was activating and every thing went smooth, Now when i send text message to some one they receive it, but when they send me text i dont recevie, Doent matter which provider, i tired (Fido, Koodo, Bell) they can receive my message but if they send me i cant recevie anything.
please help.
11-02-2016 05:37 PM
Yes, trying someone else's SIM (preferably Telus) is inconvenient but probably the best suggestion to diagnose this.
11-02-2016 10:23 AM
My Guess would be.
1- Factory Rest on your phone
2- take the sim and try on other phone and see if everythign working...
3- Try different Sim and see if sim is faulty NOW
hope you would be OK
11-02-2016 10:06 AM
Hi, could you help me out also? my sevice is totally dead for two days now which means can not call or text or use the internet at all. And Mary told me everything looks fine on my account. SO what I should do next since everything still doesn't work right now. Thank you
11-02-2016 09:12 AM
to updates, i install SMS software to see if it works, DIDNT WORK,
Tried restarting few time, Airpport mode, Manual Slection of Public mobile, Didnt work at all
any suggestion, please
11-01-2016 05:58 PM
@srlawren I've found that the number ports quickly over (within 48 hours) but the subsequent services like SMS can take some time.
11-01-2016 05:43 PM
@aa porting from a voip provider (such as voip.ms or fongo) can take quite a bit longer than porting from another wireless provider (Rogers, Fido, Chatr, Bell, Virgin, Telus, Koodo, Mobilicity, Zoomer, and I"m sure I missed a few haha).
11-01-2016 05:39 PM
I've run into this issue too. Not sure if it's related to the fact that my number was on a VoIP provider or not. When I ported my wife's phone number over, it took a few days for SMS to start working again.
11-01-2016 04:53 PM
@shoaibahmed I know it sounds weird, but many people have run into this on Android, and switching to another app seems to resolve it. You could also consider a factory reset of your phone, but as it wipes all data on your phone, I'd try a different app first to see if it helps.
11-01-2016 04:45 PM
@shoaibahmed as @srlawren suggested, you don't have something weird with your messaging client? Have you tried another client?
11-01-2016 04:40 PM
yes the phone is Androd and everythign works fine, Whatup, Viber, Phone in and out.
text i send, other receive but when some one send me, i dont receive.
11-01-2016 04:32 PM
@shoaibahmed do you receive calls on the ported number okay? If so, it sounds like your port is completed properly.
Are you on an Android phone? Could you indulge me and try an alternate SMS application, different than the normal one you use? Maybe try Textra, or if you normally use it, try Chomp? Try that, and let me know if it makes any difference?
11-01-2016 10:24 AM
11-01-2016 10:21 AM
You must be patient until the port is completely done. Until then, some things might work and some might not but when it is done you should recive a text saying that the porting is complete
11-01-2016 10:17 AM
11-01-2016 10:04 AM
Yes, the same thing happened to me, I just had to wait a reboot my phone a few times and the issue solved itself 🙂
11-01-2016 10:02 AM
OK thanks let me try that and get back to you.
thanks for quick response
11-01-2016 09:55 AM
Try to reboot your phone, set the provider to manual/select Public Mobile, put in airplane mode, then back on.
Otherwise, its a backend issue and a moderator might be able to look into it. @Shazia_K
