Picture messaging lost
TimTimTimTim
I am on your least expensive plan. When PM made upgrades in mid February, my ability to MMS was lost. Did PM remove my picture messaging, leaving me with just text capability?
Hame
Thank you for this! I just switched back to Public Mobile a few days ago, and the default settings in the SIM card are clearly wrong.
I don't know how non-geeky mortals handle this stuff. I would've been stumped if it hadn't been for this forum.
(Some kind of official e-mail update with instructions would have been nice.)
@TimTimTimTim everyone gets unlimited MMS
there might be a bit more work then simply updating.  Many confirmed that you need to delete the current APN profile first.  Then Add new profile and add according to this, please note case-sensivitve and do not add extra spaces.  Remember to save the new APN and then reboot the phone before you try
APN: sp.mb.com
         (or try all upper case SP.MB.COM)
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
         or    default,mms,agps,supl,fota,hipri
           (might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
                or  Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
if still fails , support can help and we had confirmation that that can be fixed by support.  Please open ticket with PM support:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Log In", finally click "Click here to submit a ticket ↗"
TimTimTimTim
Thanks for the quick reply.
I have a Pixel 7a and have been all through these comments and tried all possible fixes.  When I went to my account page, I saw that I have "unlimited international text".   All other plans offered by PM say "unlimited international text and picture messaging".  Did PM drop picture messaging for the cheap plan?
@TimTimTimTim what phone do. you have?? brand and model?
your phone could be affected by this announcement:
https://productioncommunity.publicmobile.ca/t5/Announcements/Picture-and-Group-Messaging-End-Date-Fe...
if you are using a device that released after 2017, generally, you can simply click Reset All networks or Reset network settings to get the latest APN
Also, you can make a manual update, here are the old and new settings
Old settings:
APN: sp.mb.com
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
New Settings:
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
