12-02-2023 04:24 PM
I’ve been having issues connecting to the network I bought 3 different esims tried factory resetting my phone and all trouble shooting steps. I just purchased a physical sim after chatting with support, I paid my subscription fees and everything should be working but it’s not, anyone have any experience with this or know how to fix this?
12-02-2023 05:56 PM
I’ve switched the sim number but no access to a computer so I did it on the app.
12-02-2023 04:32 PM
@Thedvrk @So you can log into your account ? If so
SIM SWAPPING profile tabs
Note only do this on lap top or computer/ not mobile device and reboot the phone
12-02-2023 04:30 PM
Yes it does I changed the SIM card #
12-02-2023 04:27 PM
@Thedvrk If you go into your account does the sim number on your new card match the sim number in your account?
12-02-2023 04:27 PM
@Thedvrk get support to SIM card swap the number for you and then you will be able to get codes sent to the new SIM card and access your account
send a private message To CS_Agents
