Physical SIM to eSIM
VanAlvin
I currently use an iPhone with a physical SIM. If I upgrade my phone, it will need an eSIM. What do I need to do to obtain and activate in eSIM?
2 REPLIES 2
Phil_Adelphus
@VanAlvin   If you're buying a recent iPhone in Canada it will still have a sim slot.  It's the American versions that are esim only.
slusagm
Unless your iPhone does not have physical sim slot, you dont really have to upgrade to esim
But if you want, buy the eSIM from the app.  downlaod PM app on the new iPhone, login and buy from Account page, Purchase sim card and choose eSIM
