10-25-2022 12:11 AM
hi can someone please post the phone compatibility link?
11-04-2022 03:13 PM
@Kaiello wrote:Iphone 4s or 4g?
FYI:
iPhone 3/4 APN settings cannot be updated manually. You will need to connect to wifi, access http://www.unlockit.co.nz/mobilesettings/ with Safari, then follow the directions there.
MMS text will not work with iPhone 4.; detailed info is here: https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/FYI-iOS-and-APNs/m-p/323119/highlight...
10-26-2022 10:05 PM
@hTideGnow wrote:HI @Kaiello
Yes iPhone will work on PM here
iPhone 4 or iPhone 4s would work at Public Mobile but it would need to either unlocked or from Telus or Koodo. The only iPhone that would not work at Public Mobile assume the conditions just mentioned are met would be the original 2g-only iPhone.
10-26-2022 02:01 PM
10-26-2022 01:58 PM
Iphone 4s or 4g?
10-25-2022 12:31 AM
Let us know what phone you are wondering if it is compatible?
We can check the frequencies of the phone for you.
10-25-2022 12:14 AM - edited 10-25-2022 12:15 AM
@Kaiello wrote:hi can someone please post the phone compatibility link?
The phone comaptibility checker provided by Public Mobile, to my knowledge, hasn't been working properly for the longest time. However, please be aware that no such checker or list will ever be complete. Which phone are you wondering about?
