Phone
7066
How do I use my phone internet for TV app
@7066
on the App settings for Go TV, make sure Mobile Data is allowed
also, make sure data saver mode is off.
Let us know if any other issues.  But if still cannot use data, make sure your other apps can access data without any issue
Socrates8567
@7066 wrote:
We use the Go TV app for all our TV  want to use the internet off my phone to watch tv
You should be able to use the app with no issues. On average, an hour of standard def uses about 1GB per hour and 3GB per hour of HD.  You for SURE want to stay away from 4K videos as this can use anywhere between 10GB to 15GB per hour.
Myself, I suggest using the Plex app to watch TV. They have a TON of free TV channels.
You just need to monitor your daily data usage.
7066
Socrates8567
Go to the app store and download whatever app you want? I watch my Bell TV on my BellFibe app. It will use a lot of data though.
Sansan
Do you mean sharing what's on your phone to your TV?
That would be hotshot or screen sharing.
Most devices allows you to screen share using Chromecast or a Smart TV.
