10-18-2021 07:55 PM - edited 01-06-2022 03:49 AM
This is not so much a question as a solution. Last thing I was doing was tethering data. The next time I tried to use the phone I could not connect to the internet except if I was within my home network range. Did the usual - reboot, toggle data off/on.
After some hunting around the internet I found a reference to APN.
My APN indeed had been wiped somehow. A bit more hunting and I ran across this from 2014:
Finding APN on my phone was a bit of a problem but the solution worked like a charm!
Thanks Lachlan_M !!!
and if anyone has similar problems, the 2014 solution is still good.
10-18-2021 08:27 PM
Yay! It's great to hear such success stories to balance out all the times the problem can only be solved by getting in touch with a PM agent.
Great post @karlandjennifer !
10-18-2021 07:58 PM - edited 10-18-2021 07:59 PM
whoops - removed post. I misread.
10-18-2021 07:57 PM
@karlandjennifer wrote:This is not so much a question as a solution. Last thing I was doing was tethering data. The next time I tried to use the phone I could not connect to the internet except if I was within my home network range. Did the usual - reboot, toggle data off/on.
Excellent use of trouble-shooting skills.
