10-23-2023 01:06 PM
Hi,
As title says, stuck in SOS mode this morning.
Bill paid, minutes available. Toggled airplane mode on/off. Restarted five times. Both manually and automatically selected carrier. Drove to different spots to see if it was where I was. Reset phone network settings. Both my sons who have Public are able to make and receive calls but I can’t.
Tried chatbot, links won’t work and I have no clue who to send a message to to get assistance.
10-23-2023 01:45 PM - edited 10-23-2023 01:45 PM
There could be an outage in your area. Check the outage map:
https://istheservicedowncanada.com/status/telus/map
If there are no outages in your area. Contact a CS_Agent by private messaging to look into the issue:
10-23-2023 01:41 PM
Did you try your SIM in another phone?
If opening a ticket does not work very first time, contact agent directly: send a private message to the CSA - agent by clicking (Ctrl+) Here
10-23-2023 01:14 PM
Have a look at devicecheck.ca to rule that out.
10-23-2023 01:13 PM
And also took the SIM in and out.
10-23-2023 01:13 PM
To contact a Customer Service Agent, please click on the following link.
Please be sure to keep an eye on the top right corner where you’ll see this icon show up.
