Phone plans
Joronoy
Phone plan Canada-US-Mexico, does this mean you can use your phone in Mexico too or just call Mexico?
@Joronoy wrote:
Thank you, hairbag1, this was something I would not have known.  I have no plans to head to the US, but this is very good to know.  I did check my phone and it is not compatible.  How do we know if we upgrade our phone what to get that would be compatible?
Good question. Seems like the mainstream cellphones are compatible...iPhones, newer Samies or maybe even newer Motorola's. Before you actually buy it, come here with make / model you're considering and someone can let you know.
Joronoy
hairbag1
@Joronoy
point to consider...for talk whilst in US only, you MUST have a cell that is VoLTE enabled and recognized by Public Mobile as  VoLTE ready. Here's a link for some further reading with a devise compatibility checker at bottom of page.
https://www.publicmobile.ca/en/get-help/articles/volte
You don't necessarily need a VoLTE enabled cell in Canada or Mexico as we still have 3G for calling.
Another point to consider...when you return from Mexico, you may not be able to easily downgrade plans to something cheaper. Your current plan might not even be available.
Calls work to any of the 3 countries while you're in any of the 3 countries.
Sansan
With the Canada-US, Mexico plan you use your phone for calls and data just as you would at home.
