Phone plan
06-02-2019 05:43 PM - edited 01-05-2022 05:12 AM
06-03-2019 11:27 AM
Why do you need a Public Mobile card in the US? Isn't your PM SIM already in your device?
If you don't have your PM SIM, your only option will be to get a local SIM (I suggest Ting), as they work on the same techonology as Publc Mobile, and they're decently priced. Another is Mint Mobile, which is very much the same as Public Mobile.
06-02-2019 08:23 PM
@Shaquille wrote:Is there a public mobile sim card available in the US
I know of no retailers in the states that would sell these SIM's. But I don't know everything.
06-02-2019 08:20 PM
06-02-2019 07:32 PM
@Anonymous @Shaquille The link you seek: https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/HOWTO-Purchasing-Add-ons/m-p/198974#M22572
06-02-2019 06:33 PM - edited 06-02-2019 06:36 PM
Please note that there is some US area code will not work with the US roaming add-on.
Talk option required. Calls made to numbers starting with the following six digit combinations are not included in U.S. Roaming talk Add-Ons or U.S. calling from Canada and will not be completed when dialed: 712-432, 605-562, 641-552, 605-475, 605-477, 712-775, 559-726, 530-881.
06-02-2019 06:19 PM - edited 06-02-2019 06:20 PM
@Shaquille wrote:And how do I add the add ons .. will i be able to text and call someone else from the US ?while i’m in the US Or i can only text and call someone from canada
The post from GinYVR has a link to the instructions. A user @srlawren wrote a great post on them but I don't have that handy.
You can call out to Canada and the US. You can text out anywhere.
Edit: add to the above excellent information...keyword roaming. There are other add-ons that only work in Canada.
06-02-2019 06:15 PM
If you buy a US roaming add-on, you can call/text anyone in Canada and the US - while you are in the US. You can also include DATA (if you want). When buying the add-on, remember that it is a two step process. First time, you add the money into your account. The second time, you are actually buying the add-on with the money you just put into your account. The US roaming add-ons are good for up to 10 days (including the day they are purchased).
06-02-2019 06:12 PM
06-02-2019 06:00 PM
@Shaquille wrote:So ur telling me that my plan means that i can talk and text someone in the US when i’m in canada . But if i’m in the US i cant contact somebody from the US or Canada
Correct. You need add-ons to call and text out and use data.
06-02-2019 05:57 PM
06-02-2019 05:55 PM
Thanks @Anonymous! @Shaquille I found this original annoucements with some FAQs
06-02-2019 05:51 PM
@GinYVR wrote:@AnonymousNo the $50 allows UNLIMITED Talk Canada & US
https://www.publicmobile.ca/en/bc/plans/50for8GB-3Gspeed
Correct...while in Canada. The OP is currently in the states. They need roaming add-ons.
@Shaquille: Interestingly, you can receive and take calls and texts without roaming add-ons. Just not outgoing.
06-02-2019 05:49 PM
It’s at&t
06-02-2019 05:49 PM - edited 06-02-2019 05:50 PM
or I am confused that it allos Talk to the US while you are in Canada?
06-02-2019 05:48 PM
Hi @Shaquille Does your phone display with roaming provider you are with? ie could be AT&T or TMobile etc.
Also make sure your phone's setting is set to allow roaming.
06-02-2019 05:47 PM
@Shaquille wrote:I purchase the phone plan 50$ per month with the unlimited talk and text in the United states but now that i’m actually in the U.S. i can’t call or text
All Public Mobile plans are for while IN Canada. They offer roaming add-ons for the US and only the US.
