12-28-2022 10:41 AM
Last night I was able to receive a text message. This morning, I cannot make a phone call or send text message. I tried logging into my account and it said the page has expired. Could someone please help?
12-28-2022 10:50 AM
Check if your account is active.
Public Mobile has web page cache issue so you might be looking at obsolete status. Click on little spinner refresh icons lower down. Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
12-28-2022 10:49 AM
@scandrasa Page expired error is a different problem.
Are you using browser with saved password? (maybe Chrome?)
After you picked your login name/password from the saved list, DO NOT click Login, let the browser automatically login you after and it should work
For your phone issue, try to reboot your phone once
if it still does not work, try to change the Preferred network type to 3G Only and see if the phone connects at all
If it still does not work, try to reseat the sim card once (power down the phone, take sim out for a minute, then put it back in and power up)
or if you have another phone around, test it there. It is good to test on another phone as it will force the a sim reprovision and that can solve your problem
12-28-2022 10:45 AM
@scandrasa @Also check for outages in your area
Coverage map in your area
www.publicmobile.ca/en/on/coverage?gclid=CLuo4c39yNQCFQQvaQodeZEC0g
12-28-2022 10:43 AM
Try logging in again
Try again incognito mode/private mode
Refresh page ^^
12-28-2022 10:42 AM
@scandrasa , please try accessing your account using incognito mode on the browser. See if that works.
