03-02-2022 07:39 PM
03-03-2022 12:48 AM
If your renewal date is coming up (day before renewal). There is a standard blurb that if you have AutoPay or have sufficient funds available…disregard the message and your Plan Status will show Plan Expired.
It will return to normal the next day.
03-02-2022 09:05 PM
03-02-2022 08:03 PM - edited 03-02-2022 08:04 PM
Do as i write up above, not as i write down below.
Might be confusing to a newer user who has minimal exposure to what has become a trend to include CSA contact info on the bottom of many user's posts.
I think that's all that's being proposed.
But what do i know... 🙃
Should i contact CSA, or shouldn't I... rock, paper, scissors
03-02-2022 07:51 PM
First things first, @cmbtfarm
Are you COMPLETELY without all calling and SMS and data services?
Only asking because a lot of customers believe that messaging on their self-serve on the eve of renewals cause them to believe they are 'canceled' or 'expired' or 'deactivated'.
03-02-2022 07:47 PM
03-02-2022 07:46 PM
HI @cmbtfarm How long you don't have your service? Can you login to My Account?
If you have not used PM for over 3 months, and not pay, your account would be closed. If that is the case, there is nothing you can do other than buy a new SIM and activate a new account.
03-02-2022 07:45 PM
@cmbtfarm wrote:My account got canceled like to reactivate it
@cmbtfarm - if suspended within 90 days, make a payment through self serve or calling 611 with vouchers:
https://www.publicmobile.ca/en/on/get-help/articles/pay-for-your-services-online
If suspended for over 90 days, you number, account and access to self serve is closed/gone.
03-02-2022 07:45 PM
Is your account cancelled or just your plan suspended? Can you log in or call 611 to get your basic account info? If so you can do this yourself. No need for customer support.
03-02-2022 07:43 PM
@cmbtfarm : Might you mean suspended? What recording do you get when you call 611 with this SIM in? Or has it been more than 120 days since you last paid?
03-02-2022 07:40 PM - edited 03-02-2022 07:43 PM
@cmbtfarm , what is the reason your account was cancelled? You can send a private message directly the the CSAs using this link to discuss your problem.
