Phone number
Masha2014
How can I know my temporary phone number, which I've got in activating my line?
2 REPLIES 2
hairbag1
@Masha2014
log in to your account using either web or the app. Using the app, click on Manage Subscription...you'll see all your account info including your new number.
@Masha2014 if you request porting during activation, you won't be given a temporary phone number.
The PM sim will assigned with the number you requested porting in.  before the port is completed, you will be able to make outgoing calls on the PM sim but not able to receive incoming calls
And have you received a porting authorization text from your old carrier? Make sure you still have the  old provider sim card in the phone and reply Yes to the porting authorization text within 90 mins
