Phone number transfer
Youngchul
My outgoing calls work on Public Mobile,but incoming calls are still routing through Lucky Mobile. Looks like my number transfer is incomplete. Can you please help?
2 REPLIES 2
Dunkman
@Youngchul
I have sent you the Telus team porting phon e number.  You can check your private message inbox.
@Youngchul
Did you reply to the text from Lucky confirming with YES that you are porting over to PM? There is a 90 minute window for you to reply.
To complete the porting, you will need the assistance from a CS_Agent at:
They will contact Lucky to resend the text if you miss the text. They will also complete the porting if you did reply.
