Phone number transfer
preform1223
Authorized Number transfer but cannot place or receive phone calls
12 REPLIES 12
@slusagm wrote:
when did you authorize?  usually it will be another 30 mins to 4 hours after you authorized.
Try reboot the phone first
Outbound calls aren't working.  That doesn't take 30 miutes to 4 hours.  Outbound not working isn't because of porting.
@hTideGnow wrote:
@preform1223 wrote:
They sent me a phone number to call
Thanks
hi @preform1223
who are "they" that sent you ?  was that CS_agent  ?
It's probably another customer.  CS_Agent would never tell someone to call that number.
@hTideGnow
I think he was referring to the message that  I sent him with port assistance number.
Thanks
hi @preform1223
preform1223
Thanks
hi @preform1223
 your account was not setup probably, so you will have to message PM support as I suggested above
preform1223
None of the possible problems suggested apply. Reboot didn't solve the problem.
will13am
@preform1223, are you able to confirm that your old service has stopped working?  It can take a bit of time for the number transfer to complete.  Generally when the old service stops working, the number transfer is complete.  If the number transfer is stuck, you can call the number in the link below for resolution.
hi @preform1223
make sure old carrier sim is removed and only PM sim card is there.  Reboot phone and reset network settings
if still cannot even make calls, then it is a problem with the sim or account setup.  Ask PM support agent to help
you can submit  ticket by direct message:
slusagm
hairbag1
@preform1223
removed old sim and installed Public Mobile sim ?
