Phone number suspension
Luul
Hi,I make a payment and still i can't make calls of any kind and cannot receive them either, and still it says my number is suspended.
2 REPLIES 2
slusagm
Reboot the phone and test
if you need PM's help.  Submit them a ticket.  Not sure if you receive 2FA for opening Chatbot ticket, but you can message them for help here:
HI @Luul
data work ? text work? what phone is that?
can you try once more , reboot phone and Reset network settings
